Convert DVD Title for iPad Mini
03/24/2022
The smaller size of iPad mini makes it more convenient for people to carry it in pocket than iPad. It is mini in size but it is powerful enough to playback any high-quality video. You can also enjoy DVD movie on your iPad mini only if you convert the DVD to video formats supported by iPad mini. But how to convert DVD to iPad mini? DVDFab DVD Ripper is the best DVD to iPad mini converter that can rip protected DVD to iPad mini/iPad mini (Retina)/iPad mini 3/iPad mini 4 compatible video format at a fast speed. With DVDFab DVD Ripper, you can convert DVD to iPad mini with only a few mouse clicks. The following is the detailed converting process.
Step 1: Load the source
Run DVDFab 10, go to Ripper module and load the source.
Step 2: Choose the profile
Navigate to the profile library on the top left corner of the main interface and choose Device > Apple > iPad mini/iPad mini (Retina)/iPad mini 3/iPad mini 4.
Step 3: Customize your video
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, and define the name of the chosen title. If you want, you can also click the “Advanced Settings” icon to customize your settings and click the “Editor” icon to edit the video.
Step 4: Select a directory and start the ripping process
Click the "folder" icon to select a directory to save the output video. And then you can click the "Start" button to start the process of ripping DVD to iPad mini.
If you want to convert video to iPad mini, you can turn to DVDFab Video Converter, the best video converter that can convert video to iPad mini, iPad, iPhone, iPod, and Apple TV.
